98 LS1 Z28 recall question
I have a question about the 98 LS1's. I've read that there was a recall on the LS1 cylinder head on models produced between Feb. 21,98 - March 13, 98. Has this been much of a problem? I'm most likely getting a 98 z28 on Friday, and would like to know if anyone has had any trouble with their Z. I'm afraid I'll get an LS1 that previously had the cylinder heads that were not machined properly, and it will have engine damage.
Is this anything to do with the oil consumption problem with LS1's? If not, I have not heard of any recalls ot the LS1. Early in the going for the LS1, the dealers would replace the rings on one piston because of an oil consumption issue. Now they just say it is normal and wont do anything for you. I dont think there was an official recall for this though.
Originally posted by Flat_Tire_
Recall? say what?
Recall? say what?
It was only a few hundred cars..
had nothing to do with any oil issues.. it was a spark plug hole issue.. the one cyl would lose compression somewhat around the plug.. it was a casting problem on some hundred odd heads in 98. most people didnt even know they had a problem.. i had a march 14-20th car.. i didnt get a recall
its not really an issue
Here is where I found the official recall letter http://lscamaross.8m.com/ls1recall.html But now when I click on the link, it doesn't work. Maybe one of you can get it to work..
A TSB is NOT a recall.
A Technical Service Bulletin is only designed to tell a service technician how to repair a certain device if brought in for repair.
A Recall is where letters are sent out to consumers telling them to bring in their vehicle to have a part replaced or checked due to a safety concern.
Look: http://www.alldata.com/TSB/10/981002IS.html
all TSB, no RECALLS
all TSB, no RECALLS
