97 & 98 corvette owners regulator related
I have a LS6 in a 1997 GMC reg cab step side.
I'm using the return style fuel rail off of a 98 vette.
Do I hook the regulator to vacuum or leave it unhooked?
I have done a lot of searches and never found a clear answer.
thanks, Kris
thanks, Kris
If its anything like a normal style FPR,then yes you need to hook the vacuum port to a manifold vauum port.
As you give it throttle and the vacuum goes down (such as when you stand on it to smoke the ford in the other lane), when the vacuum goes towards zero thats how it lets the fuel pressure increase to feed the injectors.
Hope that helps.
Hope that helps.
Magenta_Hearts
Mar 29, 2017 08:54 PM
carguyshu
Jan 22, 2017 11:19 AM
armedtrigger
Feb 24, 2015 08:30 PM
