60K+ Mile LS1 Owners.. Inside
Old May 11, 2004 | 11:39 AM
  #16
QUICK305's Avatar
I have a 98 A4 Trans Am. Bought at 58K - mileage now nearing 81K. Only things I've had go wrong are:
Fuel pump (ran out of gas - my fault)
Warped rotors
Power antenna
I change the oil about every 5-7K using Mobil 1 and just flushed the transmission fluid (still shifts perfectly). I have little to no oil consumption and no piston slap.
Overall it's been very reliable. Haven't even changed the plugs yet.
Old May 11, 2004 | 01:08 PM
  #17
hotrodgirl's Avatar
I have 67K on mine. It's been to the track a few times. I had a small leak in the pinion seal at 63K. She runs like a champ
Old May 11, 2004 | 01:44 PM
  #18
SSBIRDMAN's Avatar
mine has 95+kms which is about 70000miles. no problems. does use oil but that is normal. just had the car dynoed and it is still laying down good numbers with no stumbles or diffuculties. seems to be an awesome engine.
Old May 11, 2004 | 06:21 PM
  #19
Lt1 and Ls1's Avatar
Mine has forty something and has had to have a new clutch, the stupid alarm is messed up, and the rotors are WARPEDI think that's everything
Old May 11, 2004 | 08:19 PM
  #20
1stls1's Avatar
70,500 and I have owned it for about 3 months. PCV valve, needed complete fuel flush, fuel pump, 2 injectors, 2 02 sensors, PCM said to replace itself- so they did, window motor, rebuilt amp. WOW, I have a new car! Still runs great though, 13.625 in the 1/4 all stock, now too bad .
Old May 12, 2004 | 07:21 AM
  #21
MidnightBlue 98's Avatar
62000 miles and I've had the infamous o2 sensor code and a small leak (wet around the rear end) in the rear differential. Wasn't even a bad enough leak that they would fix it under the warranty because they said it would run about $1000 to fix it and would have to pull the whole rear (that was a bunch of BS from the warranty company). So I have watched it the last year or so and it is ok now.
I have never tuned it up or changed any spark plugs and it still runs great. I think it is probably time to do that though.
Old May 16, 2004 | 11:16 AM
  #22
robb4964's Avatar
123thousand.Runs like a beast . I change the oil every 3k . I drive about 100 miles a day to work round trip . No problems yet . Ifm it is anything like the Z in terms of reliability , It will never break down .
Old May 16, 2004 | 11:31 AM
  #23
ZIPPERR's Avatar
[QUOTE]Originally posted by rncotton
65K on a 2001 WS6
Oil consumption in the 1 Qt / 1K mile range
Bad cats, replaced under warranty
[/QUOTE
Just curious, Did you car burn oil at all before? Like at 25-30K? Or has it always burned oil?
Also how did you find out the cats were bad?
Old May 17, 2004 | 09:40 AM
  #24
rncotton's Avatar
I bought the car used with 30K on it. The car has always consumed oil. But, since I don't get blue smoke out the back, I'm not really worried about it.
I found out the cats were bad (actually, just the passenger side, but dealer replaced both) when I threw a code. There is a TSB for 2000 and early 2001 production cars that got a bad batch of cats.
Old May 17, 2004 | 11:28 PM
  #25
ZIPPERR's Avatar
Thanks for the reply.
Brake_L8
Jan 20, 2015 09:44 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
