Is a 3500 stall to much for a stock engine daily driven LS1?
Old Mar 18, 2005 | 01:03 AM
  #16
97z28/m6's Avatar
Re: Is a 3500 stall to much for a stock engine daily driven LS1?
Originally Posted by Capn Pete
And winter just officially ended TODAY!!!
Old Mar 18, 2005 | 05:54 PM
  #17
zo6vette's Avatar
Originally Posted by darrens99formul
You don't need any tune with a 3500 stall torque converter. If you have a 98-00 F-body then you can probably leave TM in without an issue. The 01 & 02 models have been known to throw a code and cause problems until TM has been removed or tweeked a bit.
You can just install and drive it. Just make sure you have a tranny cooler because that is a must. Shift kit is a good idea to firm up the shifts but it is not needed like the tranny cooler is. After the install you can see if you have any TM issues and if you do then just delete it. Lots of A4 folks here have deleted TM with a TC and had the trannys survive a long time.
Good luck
yes i do have a 00 Ls1 so then the torque management won't be a problem if i get a 3500 stall? i really dont wanna delete it because i don't want the trans to break and i dont have that much money to get a new trans
Old Mar 18, 2005 | 06:40 PM
  #18
darrens99formul's Avatar
You should be fine. There are no guarantees but the most common years to have issues are 01 & 02. 98-00 will be ok in most cases but there are some exceptions. But I seriously wouldn't let that stop me from doing the single best mod for our cars. Even if you have to remove TM it's not gonna kill your tranny within a week. I know guys who have run 30k+ miles without TM.
The 4L60E is not a great transmission. Unfortunately we have to accept the fact that our transmissions will fail before 80K in many cases. I'd rather have my transmission last 50K with a kick *** 3500 stall then 80K on the stock one. But that's just me. My advice is go for the 3500 stall and see what happens. If you throw codes and have some problems then remove TM. Then save a little from each paycheck to eventually pay for a beefed up 4L60E or even better a TH400.
Good luck with whatever you decide and always enjoy that ride
Old Mar 19, 2005 | 12:19 AM
  #19
zo6vette's Avatar
what kind of codes would pop up?
Old Mar 21, 2005 | 02:52 PM
  #20
P0757 is the code that pops up sometimes with the 2001/2002 models after the torque converter upgrade. It refers to "shift solenoid B stuck on" but the problem is not the solenoid. Get rid of TM and if it's a real big stall (4000+) you may need to raise the shift points so you don't bounce the rev limiter.
Not major tuning but just a little tweaking to make it all run like a champ
deadmanrunning
Jan 3, 2015 01:12 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
JordonMusser
Jun 13, 2003 11:53 AM
JordonMusser
Sep 11, 2002 12:12 AM
