275/40/17 rub on lowered car?
I just made an appointment to have springs and shocks installed. The car will be lowered 1.2 in. My next mod is to purchase new rims and 275/40/17 tires.
Will I have any problems with clearance now that the car is lowered? Will I need to specify a different offset or back spacing (from stock) when I make the purchase. Perhaps the wheel wells are big enough without any deviations?
Thanks for the feedback
My car is low, and the 275's on stock wheels never rub. I have ran WS6, Firehawk and SS 17x9 wheels. I run 315's all the way around on 17x11's now. They will rub on a hard corner, and suprisingly fit better up front than in the back.
http://24.219.29.88/front_315.jpg
http://24.219.29.88/ta_315.jpg
The only time mine rubbed was when the alignment guy adjusted the panhard bar wrong. Even then it would only rub under very hard cornering in right hand turns. I easily had about an inch or more clearance on the other side though. Convertible wheel wells used to be tighter but I think they're the same now after about 98 or so.
Dec 1, 2014 08:08 AM
squarehead
Nov 21, 2014 08:02 PM
