241 to 243 heads....
Old Dec 5, 2012 | 09:42 PM
usmc z28's Avatar
i have a question for all u guys that knows more than me.... i have a 2002 z28 a4 with slp lt, slp high flow cats, slp loud mouth catback, slp lid with bellow.... i am planning on buying a set of 243 heads to put in my camaro, would my headers still fit on those heads? also my ls6 intake manifold? does the 243 heads fit just like a 241? thanks guys just need some input... either i get 243 or get my 241 cnc ported.... btw im new here so if i made a mistake pls correct me....
Posted from Camaroz28.com App for Android
Old Dec 6, 2012 | 10:49 PM
WhiteHawk's Avatar
Re: 241 to 243 heads....
Get some ported 243 heads if you are going to go through all that trouble. Not much gain just by swapping stock castings. The Livernois guys were seeing like 50 hp from just their ported 243 heads.
-Geoff
Old Dec 7, 2012 | 02:34 PM
DANOZ28's Avatar
my 243's bolted right in. the only difference is a better flow design. (vettes have special exhaust hollow valve stems i think) going off memory stk heads flow approx 230 cfm vs ls6 / 243's flow 265 cfm. after a good porting stk aprox 290 cfm vs ls6 / 243's aprox 320 cfm. hope that helps cheers!
Old Dec 8, 2012 | 05:21 PM
usmc z28's Avatar
thanks for ur input... definitely going for the 243... i'll post pics soon as i get it done... any recommendations on what cam should i use?
Old Dec 17, 2012 | 12:24 PM
DANOZ28's Avatar
i went too mild w the 2002 ls6 cam (runs & drives like stock / no lope). the general middle of the road best cam is the tr224. if i upgrade im thinking about a 565 lift, 224/228 duration cam. if your car is an auto trans (A4) you will probably need a stall converter to help the idle. stick shift cars no problem. there are plenty of monster cams out there like the magic stick or T-rex but you can run into drivability issues going that big, not to mention you need the best valve springs. cheers & goodluck!
Old Dec 19, 2012 | 02:23 PM
rv93's Avatar
just to clarify, the ls6 had the best version of the 243 casting, and it came with hollow intake and sodium filled exhaust valves. a cheaper option is to get them off an ls2, which i believe is basically the same head, but without the fancy valves. they also came on some 5.3 truck engines, but i think they had smaller valves or something like that
Old Jan 29, 2013 | 03:40 PM
Ultra_Z's Avatar
only thing diff are bigger ports. everything bolts up... since you have ls6 intake... you already have LS6 cross over coolant lines. you'll see about 15-20hp better on dyno... i did a 243 and 02-04 zo6 cam upgrade and made 353whp and 360wtq with LS1 intake and stock exhaust manifolds... I just got a FAST 78 intake... can't wait to get it back on the dyno now!
nathan221432
Parts Wanted
Mar 29, 2015 08:29 AM
moralesrx7
Apr 12, 2005 08:18 PM
INVISIBLEZ
Mar 18, 2005 11:23 PM
BartonekDragRacing
Aug 3, 2004 09:52 AM
INTIMID8R
Jun 5, 2004 09:44 AM
