2002 noises
2002 noises
Hey guys, I just bought a 2002 6spd and I have a couple of questions. First I hear a noise coming from the passenger side of the engine when under moderate or w/o throttle. It sounds kinda like exaust but I'm not used to that sound coming from that area of the car. It doesn't sound like an exaust leak. More like an exaust droan. Also if I rev the car with the clutch disengaged the revs don't come back down very quickly. It is almost like the throttle is slow to close or something. Thanks to anyone who can help with these questions. Just thought maybe some of you might have experienced these already and could let me in on it if it's anything I should be concered with.
The revving thing sounds normal. Also, when you go WOT for the 1-2 shift and then say pop it out of gear, the RPMs will sometimes hang around 2000-2500 for a little bit because the PCM expected you to continue the WOT application.
Re: 2002 noises
Schantin
2002 Camaro Z28 M6
I was thinking that something might be wrong with the cat on that side but damn this thing is no slouch. barks third with ease on new F1s. only had the car about 4hrs. and aready put the smack down on a newer carrera on the highway. Maybe the noise will go away if I put some headers and cat-back on it....Hmmm.............
autoxr166
Sep 25, 2015 04:21 PM
