2000 or 2001, which should i get!
ok fellas,
the time is finally near.
i am starting to look for an ls1 SS.
now i really want a 2001 camaro SS but the 2000's are cheaper.
but as everyone knows, each year the automaker improves over the previous year.
i read that stuff like piston slap, excessive oil consumption, coolant leaks.. are not as common on 2001's as they are on 2000's. is this true?
i tried doing a search but i didnt get mush help.
I am not sure about improvements of piston slap, oil consumption, or collant leaks. But a big difference between 2000, and 2001 was the installation of the LS6 intake manifold on all LS1 engines. This provided more low end torque with an increase in HP. If I had a choice I would go for the 2001.
werd. but i will be modding it.. so i dont really care too much about which car has more power.
what i do wanna know is things like, what better improvements were made on the engine, rear end, tranny, brakes, suspension.
i think the o1's use a zo6 clutch right?
and the o1's have no egr?
The LS6 manifold has no EGR. Hence the EGR was removed for all LS1s from 2001 and beyond.
//what i do wanna know is things like, what better improvements were made on the engine, rear end, tranny, brakes, suspension.
It has the same rear end, same tranny, same brakes and suspension. The 01 has a better oil cooling system and the ls6 intake for a supposed 10hp gain. I figure, why spend the money for the ls6 intake for a 2000.. just get the 01. Other unimportant things the 01 has is more sound dampening to make a quieter cabin (which makes hardly any difference when you slap a new muffler on) You're pretty much comparing the same car, other than the intake, the oil cooling and the clutch.
My 01 does burn a little oil. I dont see why you shouldnt do a cam or headers on one though. The manifolds are the same on an 01 as an 00. I believe the 01+ got a slightly different cam, but they could still more than benefit from a cam swap. The big plus is no EGR and AIR restriction plus an LS6 intake.
Originally posted by red91tsiawd
get an 00 and put an ls6 intake on it....... that just gave you enough extra cash for you to get a cam and headers
My 00 does not consume any oile between oil changes (3-5K miles), no piston slap, no coolant problems and made 297hp/309lb.ft to the rear wheels when stock.
I have nothing to complain, I guess...
If money is not an issue to you, then why not get the newest possible?
TS
i found a 2000 SS
with 35000kms.
thats about 21 000 miles.
its fully loaded.
NBM , M6
and its going for 23000 cdn.
thats about 16000 us.
originally im looking for a RED car..
but the NBM isnt too bad. what do you guys think about NBM?
with 35000kms.
its fully loaded.
NBM , M6
