17x10 Inch Wheels!!!
Old Nov 6, 2002 | 09:17 AM
StylezZ28's Avatar
Ok question,
1) Will a 17x10 inch wheel fit under the stock 2002 WS6 TA.
2) If so, Does it stick out of the body?
i want to buy the Boyd Coddinton Fury's but they only come in 17x10. Any of u guys see any handling difference or anything performance wise coming from a 10 inch instead of a 9?
Old Nov 6, 2002 | 11:18 AM
Ken S's Avatar
I figure, if you fool around with the offset, you cuold probably fit them in perfectly. If the 17x11 guys can make them barely fit, perhaps 17x10 rim would give just the necessary clearance to fit without fuss? You still might be a little tight, and have to get an aftermarket panhard bar to center your rear a bit better.
17x10's would probably be slightly heavier than the x9's, but you'll be able to mount either slightly wider tire, or mount say 275's with less bulge.. so theoretically you would get more of the treadwidth on the ground with less moving around.
On the street if its noticable but how much? I dunno.
Old Nov 6, 2002 | 11:20 AM
Lucas Black's Avatar
the wheels i ultimately plan on getting for my car are 17 x 10's.
basically, if you get the right offset/backspacing....it should probably be ok.
because 17 x 9.5's fit on our cars all the time without fail, with a 275/40/17 tire.
so i feel that by going with a 17 x 10, if anything you could still most likely squeeze a 275/40/17 on those wheels, but in my hopes, i plan on trying to find a 295/35/17 tire if i can find it...i believe a 285/40/17 might work also although the overall diameter of the wheel and tire would be slightly larger than using the 275/40/17...i'll have to look into it again...if you do have a small rubbing problem, it would most likely be up front, where you might have to do a little wheel well "massaging" to make sure nothing rubs on a regular basis.
definitely try to do some more research before delving into purchasing your wheels...
...good luck...hope this helped...
Old Nov 6, 2002 | 06:56 PM
supersp0rt's Avatar
17x10 will fit fine.
Old Nov 6, 2002 | 09:29 PM
StylezZ28's Avatar
Ok i am going to call boyd up anyway and see whats up. I would love to get a 17x9 fury if i can.... maybe custom made by them or somethin. Anyway thanks for the replies
Old Nov 7, 2002 | 07:06 AM
ZBLKHELLRZR's Avatar
Thumbs up
17X10 you'll need a 40mm offset to clear.
Old Nov 9, 2002 | 12:49 PM
vendela99's Avatar
I had 17x11's and they barely stuck out, and they looked awesome. I got more compliments on the back tires than I did on my car. Make sure you get a good street tire though or you'll lose you car like I did.
PCLZ28
Wheels and Tires
May 8, 2015 08:39 PM
mark0006
Apr 21, 2015 12:42 PM
TitoPR221
Jan 2, 2015 03:51 PM
Z284ever
53
Aug 7, 2002 11:06 PM
