160 thermostat help
Old Jul 13, 2007 | 08:32 PM
Snugans310's Avatar
160 thermostat help
i just installed a 160 slp thermostat in my car an i wanna know what temp do i have to set my cooling fans
Old Jul 13, 2007 | 08:57 PM
Snugans310's Avatar
ohh yeah i have a 2002 camaro ss m6
Old Jul 14, 2007 | 05:56 PM
Snugans310's Avatar
Help Help Help
Old Jul 14, 2007 | 06:12 PM
2001NBMZ28's Avatar
What programmer are you using? I can set mine in one degree increments and programmed them to come on at 184/off 175 for low, and on 194/off 185 for high. Mine run quite a lot here in Florida.
Old Jul 14, 2007 | 06:29 PM
Snugans310's Avatar
i have a diablo tuner
Old Jul 14, 2007 | 06:41 PM
SSpdDmon's Avatar
I dropped mine 40*F below stock...
#1 ON-186 OFF-179
#2 ON-193 OFF-187
2001NBMZ28's Avatar
That's what I'm using - try those settings and see how it works for you - you can change them anytime to make them come on at higher temps. Write down your currrent settings in the back of the manual so you know what your starting point was. BTW, you won't see much difference on the stock temp gauge.
Old Jul 14, 2007 | 10:33 PM
lsxprotour69's Avatar
why do you use lower temp thermostat in your cars. I was alway told to run a engine hot and it will produce more power. Will the new cars advance the timing if the engine runs cooler. Teach me
Old Jul 15, 2007 | 04:27 AM
AL SS590 M6's Avatar
Moderator
Fossil fueled engine temps have always been a compromise. You need heat in the combustion chamber to promote a good burn for good power and effiency but you want cold air into the engine for the same reasons.
A cooler stat and lower fan settings reduce underhood temps and keep the air charge cooler without hurting the temps in the combustion shamber too much.
For what it's worth I don't believe in a cooler stat for stock LS1s. I don't think that there's any performance gain. But when I went heads/cam I too went to a 160° stat and the above mentioned fan settings.
G-BODYT56
Jan 14, 2022 11:14 PM
Jeff1904
Jun 5, 2016 05:00 PM
chevy94c
Mar 26, 2016 08:53 AM
Bobczar
Oct 23, 2015 11:22 AM
MikeWhitener
Aug 2, 2015 06:17 PM
