160 degree thermostat in 02 LS1 in the winter months
Old Apr 28, 2003 | 11:41 PM
gearslammer's Avatar
Will I notice a decrease in driveability d/t a the fuel mixture being too rich. I currently have the HPPIII in an M6 and can adjust for the stats but I was told winter/or the cold could cause some problems. ???
Old Apr 29, 2003 | 01:13 PM
I know the car won't get as warm (boo hoo) but aside from that any other comments???
Old Apr 29, 2003 | 06:04 PM
stik6shift98's Avatar
i have it and mine is fine in the cold and car still gets warm enough
Old Apr 29, 2003 | 09:24 PM
someone finally. thanks
Old Apr 29, 2003 | 11:07 PM
Bone Maro's Avatar
Do not put a 160* in your car. In 00, GM designed the LS1 to run at 210* for emissions purposes. If you put in a t-stat that cold, I've heard people saying their cars throw the SES light because it's too cold for the PCM, and will make it think it's not meeting emissions. That's why they make the LS1 180* t-stat, for the 00+ cars.
Run a 180*, it'll run a lot cooler and still keep you from popping that SES light
Old Apr 30, 2003 | 12:15 AM
Bone, would the HPPIII override this. It asks specifically which stat is being used. I assume for that purpose of reprogramming the PCM.
Old Apr 30, 2003 | 02:47 AM
camaro98_speed's Avatar
I installed a hypertech 160 thermostat in my 2002 z28 and have had no lights or problems. I have the predator, which allows me to adjust my fan settings. But even with the predator off the car I still get no SES lights or anything. The car's heater still gets hot, and the defroster still defrosts with the quickness. I like the mod.
Jp
Old Apr 30, 2003 | 06:44 AM
Drumhawk's Avatar
I bought the slp 160' thermostat and fan control switch but haven't yet installed it on my 02 firehawk. You got me thinking now? Should I install it or not? Slp doesn't make a 180' thermostat that I saw. I'm not so sure I like slp anymore.
Old Apr 30, 2003 | 09:31 AM
2001NBMZ28's Avatar
I have a 160* tstat and my fans set to come on early optimized for it with HPP3. No codes or other issues, of course I'm in Florida. The stock tstat is 180* To run cooler in traffic with the A/C off you need to get the fans on at a lower temp.
Old Apr 30, 2003 | 09:44 AM
Bone Maro's Avatar
The HPP series doesn't tell your PCM that a lower temp t-stat is in there. It just allows the fans to come on at a lower temp to keep the car cooler. The temp range for which they come on depends on what t-stat you're using.
And the 00+ cars did not come with a 180* from the factory. I believe it was a 195*. That's why when you drive a 98-99 at operating temp, it stays right above the first hash mark. On a 00+, it stays right in the middle.
Emissions requirements. The hotter an engine runs, the better emissions it puts out.
Old Apr 30, 2003 | 10:33 AM
rncotton's Avatar
I'm running a 160* thermostat in my 2001 WS6. It never threw a code during the 6 months I had it installed without changing the fan turn on point.
I used the HPP to change the fans turn on, and still don't get an SES light.
As for winter heating ... I still get plenty of heat in the winter.
Old Apr 30, 2003 | 10:41 AM
i have never heard of them throwing a code.....thats in my opinion
Old Apr 30, 2003 | 10:47 AM
2001NBMZ28's Avatar
Hmmm...my HPP3 book says stock tstat is 195, but my owners manual says 180 for the LS1/195 for the 3800 V6.
Old Apr 30, 2003 | 12:28 PM
PhantomTA's Avatar
Moderator
it runs 210 because the gauge is fudged..
160 is absolutely fine
Old Apr 30, 2003 | 09:10 PM
Bone Maro's Avatar
Explain.
