y-pipe rattle
y-pipe rattle
anyone with a pacesetter LT y-pipe: does yours rattle on the torque arm too? cuz mine's friggin annoying. whenevr i get on the gas or especially when i spin the tires it'll rattle right on the torque arm and iyou can feel it pretty good. has this happened to anyone else? or is mine perhaps crooked or bent? i've tried reinstalling it, but its as low as i can make it hang.
Re: y-pipe rattle
try readin this thread y-pipe hits floor when under power
Also try the search button I know there has been atleast 3 thread about this in the last 2 months.
but my does it too, I just went and bought poly motor mounts this week now I just goota find time to put them on and hope that fixes my problem
Re: y-pipe rattle
Yeah, mine was doing that as well under hard acceleration. It was a little worse for me because I have a cat welded in that area as well at it was butted pretty close to the torque arm. I wrapped the y-pipe in header wrap as a temporary fix and it did a good job of dulling the noise. I just installed a crossmember mounted torque arm yesterday so that problem is now history.
Re: y-pipe rattle
Originally Posted by TJ Chapman
which torque arm did you buy? cuz i was thinking of that even before the y-pipe problem.
Re: y-pipe rattle
the spohn unit eliminates and replaces the crossmember. this meaning the trans crossmember correct? so i might as well buy a poly mount for that as well?
Re: y-pipe rattle
Here is the link, it has installed images so it gives you an idea. http://www.spohn.net/product.cfm?productid=1329
Re: y-pipe rattle
oh 200gtp you have the pacesetter y-pipe. . .and the spohn stuff fits all good? the y pipe fits under the new brace? and did yours not origionally fit under the stock tunnel brace?
plus what does chromoly do for ya? is it worth $115 if i run at the strip and perhaps some crossin? spherical front bearings too? good idea? or too harsh for street?
how do you install the driveshaft loop on this piece? must you disconnect the front of the driveshaft and slide it through?
Re: y-pipe rattle
autoxr166
09-25-2015 04:21 PM
squarehead
11-21-2014 08:02 PM
