Y-Pipe to Cat; Weld or clamp?
Old Dec 28, 2005 | 10:28 AM
F Carline 94's Avatar
It seems like the clamp that came with the cat or y-pipe (can't remember)would be easier for disassembly purposes. I am not all that confident about getting a good seal though.
I have an SLP Y-pipe and Random cat. I could get it welded for nothing at the muffler shop I use.
Suggestions?
Old Dec 28, 2005 | 11:50 AM
Kataklysm's Avatar
Re: Y-Pipe to Cat; Weld or clamp?
I weld my exhaust in every spot. Granted if you need to take it down you need to cut it but it can always be welded again.
Old Dec 28, 2005 | 01:08 PM
2000GTP's Avatar
Welding will give you a better seal in my opinion. I am using band clamps to seal up every part of my exhaust, but that is for the purpose of easy future dissassembly.
Old Dec 28, 2005 | 01:31 PM
94Z28/SSw's Avatar
I have mine welded, less rateling noises.
Old Dec 28, 2005 | 01:53 PM
Marky82's Avatar
You Should Def. Weld It. I Love To Weld. Its Cool.
Old Dec 28, 2005 | 02:12 PM
wrd1972's Avatar
If its welded then it will not be fune to have to remove for what ever reason.
I installed 3" 3 hole flanges on mine and could not be happier. I have no leaks period.
I have this one flange left over with gasket for sale $15.00 shipped anywhere usa.
Old Dec 28, 2005 | 08:04 PM
Chevycobb's Avatar
I used the 3 point flange on both ends of the cat and ORP, so I can bolt them up when needed (emmisions tests ) if i have a leak there oh well..exhaust is loud enough to cover it up
Old Dec 29, 2005 | 07:20 AM
wrd1972's Avatar
Same here, I can remove my cat and bolt in my straight pipe in 10 minutes and vice versa. If properly installed with proper gaskets they will not leak.
Aug 22, 2015 01:09 AM
4586
Aug 18, 2015 07:08 AM
karpetcm
Aug 14, 2015 03:02 PM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
