xe comp cams 230/236 at 112 lsa on LT-1 stock heads
Old Aug 20, 2004 | 03:51 PM
ram air camaro's Avatar
who out there are running that cam on a full bolt on LT-1, what times are you running ??
boltons like
1.6 rr
long tube headers
high stall,etc
Old Aug 20, 2004 | 09:44 PM
teke184's Avatar
Re: xe comp cams 230/236 at 112 lsa on LT-1 stock heads
that's ALOT of cam for stock LT1 castings...
i would think it wouldn't be worth it....
Old Aug 25, 2004 | 09:48 PM
ws6transam's Avatar
boltons like
1.6 rr
long tube headers
high stall,etc
I've got that very same cam in my Minirammed 385 stroker engine, though it's not yet finished. I got the cam from a nearly identical engine, and with a Accel DFI computer, 3200 RPM vigilante, 30 lb. injectors, ported AFR 195's, 3.42 gearing, and a 3500 lb race weight third-gen Trans Am, was supposedly doing high 11's at 119 mph in the Chicago area back in the fall of 1999.
HTH,
--Dan
Old Aug 26, 2004 | 11:52 AM
i also got that cam in my z28 but i wanted to see what times people are running? thanks on the reply's though
Old Aug 26, 2004 | 02:15 PM
importeater's Avatar
Im thinking about running that cam aswell with stock heads so Im interested too.
Old Sep 7, 2004 | 01:56 PM
onthemat's Avatar
I'm interested in this also.
Old Sep 7, 2004 | 02:48 PM
i could tell you guy's by friday night when i try my 94 z28 a-4 w/ the 230/236 cam.
Old Sep 7, 2004 | 05:13 PM
unvc92camarors's Avatar
be sure to let us know
this looks to be the cam i will be going with unless i eventually save up for a custom cam fitted to p/p stock heads
Old Sep 11, 2004 | 03:41 AM
bad new's stupid car , hesitated on the 1-2 shift and wouldn't shift the 2-3 i just kept missing it started at 5800 rpm and stayed there for a wile and jumped to about 6100k and i had to let go of the gas because i't felt like it was going to blow up or something.
here's it
60' 1.968
330 5.809
1/8 8.939
mph 79.24
1000 11.729
1/4 14.344
mph 83.93
i might want to add the my engine got on fire two days ago for about 10 second's or so not big i also sprayed it with water all over the engine so i think my opti is crapped out,i only burned some vaccum hoses wich i already replaced. sorry guys i dissapointed yall the car felt real strong early that week but not on thurs,friday.
Old Sep 11, 2004 | 10:12 AM
here's it
60' 1.968
330 5.809
1/8 8.939
mph 79.24
1000 11.729
1/4 14.344
mph 83.93
man, that sucks dude
get that worked out and hopefully you can report back to us with some better results
Old Sep 11, 2004 | 01:18 PM
Loading's Avatar
That seems like a really low 1/4 for such a low MPH, is that because you couldn't get the 1-2 shift or what?
Old Sep 12, 2004 | 11:20 AM
LT1Squirrel's Avatar
he let off
Old Sep 12, 2004 | 03:35 PM
yeah i let off at about the 1/8 mile where it hesitated and all you can see is another camaro pass me up at the end really fast like he had nitrous , that camaro ran a 13.9 and i was up ahead pretty good.
hey guy's try to help me on this one i'm tryin to look for the cause of the hessatation
http://web.camaross.com/forums/showt...75#post2472075
Old Sep 15, 2004 | 12:36 AM
atljar's Avatar
My buddy ran stock heads, most bolt ons, 3k stall, 373s with 230.236 on 110lsa.
Car went 12.19
Heres a video of us running each other. I spun really bad.
http://www.s89572780.onlinehome.us/C...sJared12.4.WMV
Here is his 12.19 run
http://www.s89572780.onlinehome.us/CarVideo/Dj12.19.WMV
Old Sep 15, 2004 | 07:21 AM
wow and on a 110lsa!! how high is he reving that thing? Seems like he's just asking for a spun bearing.
