Would an AC compressor still engage if...
Old Jun 16, 2008 | 04:26 PM
lbrowne's Avatar
There was no refridgerant in the system at all? The freon was drained from my 96 LT1 and I'm going to fix this soon however I noticed if I turn on AC the compressor clutch doesn't engage....
Old Jun 16, 2008 | 04:32 PM
ulakovic22's Avatar
No, the compressor has a low pressure cut off. Once you pull vacuum on the system and refill it it should work again. You can bypass the switch if you want to test it to be sure though. System is 1.5lbs if I remember correctly.
Old Jun 16, 2008 | 04:35 PM
94_PatriotRed_Z's Avatar
My still engages and it has no R134A in it currently. I broke the line that runs near the battery last summer, and it all escaped. And the capacity for my is 2lbs of R134A
Old Jun 16, 2008 | 05:09 PM
ulakovic22's Avatar
Is that 2lbs with oil or without? Most of the time systems require a .5lb of oil. Generally people can fill with two cans of R134 which would be a little over 1.5lbs.
Old Jun 16, 2008 | 06:48 PM
lbrowne's Avatar
Canadian Tire has this new recharge system but it doesn't say r134a on it. However it indicates it is for late model AC systems. I was just going to get that and charge it up once I replace the hose.
War Engine
Sep 18, 2015 07:28 PM
jackpawt883
Sep 10, 2015 08:53 PM
WPHIG2
Aug 27, 2015 06:37 AM
4586
Aug 18, 2015 07:08 AM
karpetcm
Aug 14, 2015 03:02 PM
