Which wire do I hook my SHift light to!! Please help
Old Jun 8, 2005 | 05:12 PM
WhiteboysZ28's Avatar
I have a pro Shift light in my car & I cant get it to light up at the RPM that I have the pill for . I have hooked it to the white with Black stripe wire & it lights up during start up but wont light up when I hit 3000 Im just testing with my smallest pill , then I hooked it to the plain white wire same thing lights up during start up but not when I hit 3000 please let me know what im doing wrong here , Im using the wires at the coil .
Thank you in advance
JOSH
Old Jun 8, 2005 | 07:16 PM
1racerdude's Avatar
Re: Which wire do I hook my SHift light to!! Please help
JOSH
Hook it up to the tach wire under the dash.
Old Jun 8, 2005 | 07:32 PM
Which one is that ?? SOrry I dont have a clue .
JOSH
Old Jun 8, 2005 | 07:39 PM
jchevy's Avatar
Do a quick search and it will come up. I pulled mine from a wire coming out of one of the connectors in the PCM.
Old Jun 9, 2005 | 03:08 AM
Johnny-Z-Man's Avatar
JOSH
I don't know what your doing wrong, The white/black wire is the correct tac wire at the coil.
Old Jun 9, 2005 | 03:20 AM
thats what I was told , weird like I said it lights up during start up but not at the RPM , I wonder if I have a bad light ??
JOSH
Old Jun 9, 2005 | 03:25 AM
JOSH
It's very possible, especially if you tapped into the wrong wire you may have damaged it.
Old Jun 9, 2005 | 12:32 PM
but it doesent make sense that it lights up during start up but not when I hit the right RPM something isnt right!!
JOSH
Old Jun 9, 2005 | 03:40 PM
JOSH
Josh,
I’m thinking you tapped into a positive wire and damaged something in the shift light.
The correct tac wire (at the coil) is white/black and has a negative polarity.
Johnny Z Man
Old Jun 9, 2005 | 03:49 PM
that was the orgional wire I had it on when I got the light & it never worked right . SOmething was probaly wrong with the light from the get go.
JOSH
Old Jun 9, 2005 | 05:05 PM
jchevy's Avatar
Try a different pill and maybe tap into a different signal wire.
Old Jun 10, 2005 | 02:17 AM
I did thry 2 different pills I have like 5-6 , as for a different signal wire where??
JOSH
Old Jun 10, 2005 | 07:44 AM
jchevy's Avatar
I cant remember which wire it is, but if you do a search on tach install or shift light install there is a wire that comes out of one of the connectors on the PCM that you can use.
Old Jun 10, 2005 | 11:15 AM
Ok I see what I can find thanks if not screw it , It looks good on the dash , LOL
JOSH
ldtantlinger92
Jan 19, 2015 01:26 PM
blac94Z
Jan 12, 2015 05:44 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
Krab
Aug 5, 2002 12:08 AM
