Window Rattles Part 2
Old Sep 24, 2005 | 12:45 PM
BadgeZ28's Avatar
the driver's door window in my 01 Z-28 rattled badly when in any position other than all the way up or down. I did a search and found suggestions to adjust the two pads that push against the glass at the top of the door sill. Did that, and they actually were pretty well adjusted as I found them. I took a look into the door housing for lose parts and then put everything back together. Didn't solve the problem. What it turned out to be was the rear guide roller assembly. It is a pressed or wedged fit to the window support frame and it had worked lose. The thing has the guide wheel and then about 3/4 inch aluminum standoff. I took a dremel tool with a abrasive barrel shaped bit and ground of the back to allow removal. It leaves a 1/4" hole. I ground off the remaining protrusion were it went into the window frame. I drilled and tapped a 1/4" 20 hole and reinstalled it with a star washer and Loc-tite.
Old Sep 24, 2005 | 02:40 PM
TraceZ's Avatar
Re: Window Rattles Part 2
Good Job!
Many people end up replacing window tracks when the guides loosen up or wear out. The rear guide you are talking about is a very common problem on f-bodies. It sounds like you found a good way to correct your without replacing it.
Fatdog2
Jan 24, 2015 12:08 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
squarehead
Nov 21, 2014 08:02 PM
The Seer
Nov 20, 2014 06:32 AM
