Will a LS1 heater hose core work on a LT1?
Old Nov 27, 2004 | 03:13 AM
ishz28's Avatar
I want to replace my 11 y/o hoses. What is the quality of the Goodyear Super Hi Miler Hose Kit. Will it give me everything I need for the car, like the steel tubed and clamped double heater core hoses, that's 168 freakin dollars at the dealer. If not, I found some brand new LS1 heater core hoses, will those work?Thanks for your advise.
Old Nov 28, 2004 | 05:17 AM
ishz28's Avatar
Re: Will a LS1 heater hose core work on a LT1?
Anyone?
Old Nov 28, 2004 | 01:21 PM
Pandamonkey's Avatar
Really the only way to tell would be to try it.
I doubt that anyone here that has a LT1 and a LS1 would honestly be able to answer your question - it's just unlikely that anyone has tried it.
They are semi-flexible so it may work.
Old Nov 28, 2004 | 01:28 PM
Mtrhds94Z's Avatar
The Goodyear Hi Miler is a good kit.. it has 10 of the 11 hoses for the car [it is missing one heater hose that goes from the flow restrictor valve to the hard line of the heater pipe, but you can use a piece of 3/4" hose for that..]
The heater pipes do not come with it [ and they are aluminum, not steel..]
You Dremel [carefully!] the swaged on factory clamps off then use regular worm type clamps for the new ones..
Also, I see that you have a 94 so the Hi Miler is for 95-7[different hose configuration ] even tho I recently saw that Summit changed their listing from 95-7 to 93-7 that's wrong..]
It is possible to update to 'late' [95-7] hose configuration.
I have no idea if LS1 hoses would work, since I have never worked on an LS1..
Britbilly
Jan 7, 2015 08:49 PM
Jazsun
Dec 29, 2014 12:14 PM
pologreen97z
Dec 2, 2014 10:42 AM
Black93lt1
Nov 21, 2014 07:30 PM
Jul 4, 2005 05:00 PM
