wierd question
wierd question
i was wondernig what would happen if i shut my car off by turning the key when i was going on the freeway?
what would happen if i were to try to put it into park or reverse while going on the freeway?
Re: wierd question
Re: wierd question
i was driving late last night and i was wondering while i was driving... i wonder what would happen if i threw it in reverse or park.... or if i just shut my car off... and i was thinking about trying the shut off thing but not the switching gears becasue i figured that would F my car up.
I thought i would ask to see how it would hurt my car
Re: wierd question
If the engine is turning it would still have oil pressure becausr the oil pump is driven off of the cam. With the transmission in nuetral it would just coast, but this is bad for the transmission, just like towing it in nuetral, the transmission has to turn but the engine is not turning the front pump on the transmission therefore not lubricating the transmission. Throwing it into park or reverse would lock up the rear tires wether the engine was turned off or not.
Re: wierd question
[QUOTE][I think with 4L60E's they have a safety feature so your car just turns off if you put it in reverse or park while your going over 15 mph./QUOTE]
put it never in Park if your car is not standing still, the 4L60E has no safty feature for this!!
Re: wierd question
Well i know for a fact the engine turns off if you put into reverse above a certaine speed. Im not positive what happens if you put it into park though. But anyway why would you do this. Just dont do it.
Re: wierd question
Turning it off is the same as the engine dying. When I modded my car and didn't have it tuned, it used to die on me all the time, even when I was on the freeway.
After it would die, I would just drop it into neutral, restart the engine, and put it back into drive (while moving). Didn't seem to do anything too dramatic to the engine or tranny.
