Where's a good ground under the dash
Old Mar 2, 2005 | 10:46 AM
bad1LEz's Avatar
Hooking up some guages and instead of running ground wires behind the pcm and out into engine bay, anyone know of a good ground in the cabin maybe under the dash somewhere?
Old Mar 2, 2005 | 11:01 AM
94Z28WP's Avatar
Re: Where's a good ground under the dash
There's a nut (10 mm I think) on the bottom left above the kick panel that connects the dash to the body... I've used that before.
Old Mar 2, 2005 | 11:06 AM
teke184's Avatar
how bout any of the ground wires for the cig lighter, radio or things like that?
Old Mar 2, 2005 | 11:16 AM
bad1LEz's Avatar
That nut does not ring a bell but I will look for it.
I was thinking along the lines of a nut, but I guess splicing into another ground wire should work. I have 2 grounds to connect, so just combine them, strip away a bit from the cig. lighter ground wire, and connect all of them together? Would it be ok to just elect. tape all together then? Without looking at the lighter wires in front of me, what color is that ground wire...green?
Thanks all
Old Mar 2, 2005 | 03:32 PM
94Z28WP's Avatar
You'll have to remove the drivers side kick panel and it's behind that.
You can use the cigarette lighter ground or something similar.. I usually stay away from tapping into other grounds just because of having to strip, splice, and tape the wires.. Easier just to unbolt a bolt and place a ground there... I'd stay away from any radio grounds though... Could cause noise in the radio.
Old Mar 2, 2005 | 03:39 PM
There is a big ol' ground lug under each front kick panel just below the dash.
Old Mar 3, 2005 | 12:34 AM
Z95m6's Avatar
The nuts are right up by the dash. They are pretty hard to miss. Thats where i would hook your grounds too.
Old Mar 3, 2005 | 06:26 AM
bad1LEz's Avatar
crystal clear now. Thanks a lot everyone.
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
ldtantlinger92
Jan 19, 2015 01:26 PM
chuyz28
Parts Wanted
Jan 7, 2015 05:25 PM
