whats the worst that can happen?
Old Nov 14, 2006 | 05:00 PM
Chevycobb's Avatar
Ok so I FINALLY got around to begin tearing down the motor.(needs another rebuild after only 500 miles but thats a whole other story) I went ahead and started pulling off as much as I could because I have to have it towed to my parents house so I can use their garage because I don't have one at my place, and when I get it there I want to begin pulling the bottom end apart as soon as possible. I pulled everything off, so the only thing there is: the tranny and block(with internals and oilpan)...so no heads, intake and accessories.
Now, what sucks is that we are supposed to get a lot of rain tonight, tomorrow, and probably thursday (about 2-3 inches). The way my car sits on the driveway water would run into the engine compartment from up top. I covered the block with three large trash bags hoping that no water would get in there. If water is to get in there, what kind of damage could that cause? should I be worried about any rust spots forming anywhere? If I do see some surface rust, should I be worried?
The block will ultimately be take to a machine shop for cleaning. The only thing in that block that will be reused is the cam. I'm just worried that what if any water gets in there through the oil passages, or maybe in the cylinders.
What are your guys opinions??
Old Nov 14, 2006 | 05:04 PM
Capn Pete's Avatar
If the block is getting stripped and brought to a machine shop anyway, they can hot tank the block and clean it up . Chances are though, you should be ok with the bags over it .
Old Nov 14, 2006 | 06:35 PM
razor02097's Avatar
X2
If the block is getting machined in any way the machine shop will bathe the block before and after machining...(before so they don't gum up their machine's coolant system and after to get rid of metal shavings)
If your saving the cam then pull it, spray it with lube and wrap it in a towl.
Old Nov 14, 2006 | 06:45 PM
Chevycobb's Avatar
cool, as long as the cylinder walls are ok i'll probably just have it cleaned. its already bored .030, so I hope that it won't need any machining with less than 500 miles on it. thanks guys, I feel a little better about leaving it out there now.
Novo
Jun 14, 2016 02:58 AM
Bxlt1
Sep 29, 2015 03:18 PM
jackpawt883
Sep 10, 2015 08:53 PM
damnyankee36
Sep 9, 2015 07:06 PM
