what would this combo typically run?
my car is a 1993z28 with an m6.
i just bought a cc305 cam. with full supporting mods (look in sig) along with an electric w.p, 30lb injectors, bigger tb etc. along with a custom mail order tune, what do you think i will be running. suspension is stock with front sway bar removed, on 245 nitto drag radials. my cars also about 200 pounds lighter then stock.
im hoping for some very low 12s, possibly high 11s? based on traction. im at negative sea level and assuming this is under optimal conditions. so what do you think? im gonna run it at a track next year but id like to know what ballpark im in,thanks for any help
12.6-13.0 depending on your 60". 60" is the key to low et's, there's no way of reallying knowing you just have to get to the track.
i would expect anything in the range above, but i think its gonna be 12.9ish.
do you really think it will be that slow? i know its not my car but theres bolt on- only cars in the 11's, i would think with a cam i should at least hit bottom 12's, guess theres only 1 way to find out..
Maybe LS1's...with all bolt on's and full suspension...shocks, LCA's, SFC's, ....etc. I personally have only seen 1 bolt on only LT1 hit 11's. And it was a 3rd gen with an LT1 in it. It had all of the above plus ALOT of weight reduction. Maybe a good 400lbs. But as you said, there is only one way to find out
oldschool
Feb 9, 2016 09:21 PM
