What would cause my battery terminals to spark up??
Old Apr 20, 2008 | 05:41 PM
TeamingTealZ28's Avatar
I just installed headers and a power master starter.
I go to put the battery terminals back on. The negative one was already on I never took it off and the positive one once it touches the battery, it sparks like crazy!
I dont know why. Starter wires are good and tight
Any suggestions?
Old Apr 20, 2008 | 05:58 PM
Chevycobb's Avatar
just spark when the wire makes contact with the terminal at the battery?
Old Apr 20, 2008 | 06:07 PM
No. Like when i screw it in. I hear it sparking, and like sounds like the freakin battery is gunna explode lol. I have no idea
Old Apr 20, 2008 | 06:30 PM
There may be a couple of items putting a drain on it-like doors open and interior lights on or such. The computer draws just a little bit of power.
BTW, if I can make a suggestion, always remove the negative cable-not the positive. If you are turning the wrench on the positive cable and you hit the body with it, sparks will fly. It is always safer to remove the negative.
Old Apr 20, 2008 | 06:41 PM
Its not being drained though.
It just sparks like crazy once I touch the battery with the cable. I dont know what else.
Old Apr 20, 2008 | 06:43 PM
Chevycobb's Avatar
maybe its just that good of a battery
Old Apr 20, 2008 | 06:44 PM
no lol
Old Apr 20, 2008 | 11:01 PM
cotton42090's Avatar
are all the starter wires hooked up right?
Old Apr 20, 2008 | 11:29 PM
All modern cars spark a little when you reconnect. If it is sparking significantly, then there is something that is pulling power or shorted.
Old Apr 21, 2008 | 09:49 AM
This is a light show when the terminal touches lol
Old Apr 21, 2008 | 10:34 AM
Chevycobb's Avatar
check all wires going to the starter and all grounds including the to the side of the block. make sure all are tight and in the right spot, and no wires are shorting out on anything else. take a god look around shoebox's site at pictures and diagrams if you haven't already. will be one of the best sites out there for lt1 info
Old Apr 21, 2008 | 11:07 AM
Capn Pete's Avatar
That's normal! Just attach the darn thing, tighten it up, and it'll stop . You'll hear relays clicking, lights will flash, everything. It's normal!
Once you've attached the battery and seen that everything went fine, let us know!
Old Apr 21, 2008 | 11:16 AM
b.lee's Avatar
Agreed.
Always disconnect negative first, on anything
Old Apr 21, 2008 | 11:41 AM
No this wasnt normal. The positive terminal turned bright red, and i heard like the battery boiling. No joke
So i took off the negative cable
Old Apr 21, 2008 | 12:04 PM
danhr's Avatar
turn the key off
