What other whole rear ends from F-bodies can I put on my car?
Old Sep 2, 2004 | 10:02 AM
ishz28's Avatar
I've heard that 1st and 2nd gens. have strong rear ends. Can any other gen. be put in my car without too much trouble. Also, will I lose ABS. I have a non traction control 94Z. Thanks.
Old Sep 2, 2004 | 10:24 AM
MrDude_1's Avatar
Re: What other whole rear ends from F-bodies can I put on my car?
you can fit any rear from a 3rd or 4thgen. 1st and 2nd gens dont have the TQ arm provisions, or the correct brackets.
you dont want a pre 89 rear since they have smaller spline axles. 89 was a changeover year, so some have it some dont.
any 3rdgen rear is going to be about 1.5" narrower on each side. your wheels will tuck in more.
any 4thgen rear fits with the stock offset. but running LT1 brakes on a LS1 rear causes the brake carriers to rub. you need to either grind them so they dont rub, or run LT1 axles.
Old Sep 2, 2004 | 10:53 AM
ishz28's Avatar
Thanks, I was trying to find a cheaper way out of buying a 12 bolt. Good info.
Old Sep 2, 2004 | 12:46 PM
MrDude_1's Avatar
if you can find one (good luck) the Dana44 was offered as a heavy duty dealer option for the 3rdgen...... GM no longer has them as SLP bought all of them from GM in 92.... SLP no longer has any either, so your only chance is used.
Old Sep 2, 2004 | 02:08 PM
Ucantcme57's Avatar
How many bolts does this Dana 44 Have? How would I tell it apart from any other 10 bolt?
Old Sep 4, 2004 | 10:41 AM
Bud M's Avatar
http://www.drivetrain.com/GMtrkratio_posidata.html
Scroll down, there is a chart showing the different cover gaskets
oldschool
Feb 9, 2016 09:21 PM
ModdedNerd
Dec 25, 2014 05:51 PM
FredM
Dec 18, 2014 01:40 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
