what kinds of heads to go with..??
Old Apr 7, 2006 | 03:43 PM
Rami08's Avatar
i recently took my heads off. both were cracked so i need replacements.now i got about 1500 to play with..but i was also thinking about new pistons cam, while im at it. any suggestions were to look for low prices and what is in my budget..greatly appreciated
Old Apr 7, 2006 | 03:50 PM
2000GTP's Avatar
Re: what kinds of heads to go with..??
One of the favorites on this board is Lloyd Elliot, he ports heads for affordable prices. Here is his site: www.eportworks.com
I'm not sure if he can repair your heads, but you can probably find a core pair for under two hundred bucks, send them to him and if you go with the LE1 package, you can get good flowing set of heads for under a grand.
Old Apr 7, 2006 | 04:57 PM
teke184's Avatar
would kindda help if we knew what kind of car!!!!
Old Apr 7, 2006 | 05:25 PM
Rami08's Avatar
yeah right.haha 93 z28 355 .
mods-SS 3" exhaust,Camaro SS brakes, T-56 transmission with Pro 5.0 shifter and SLP shift ****,Spec stage 1 clutch,CSR electric water pump,SLP ceramic coated long tube headers,McCord 3" electric exhaust cut-out,26 lb fuel injectors,Moroso cold air intake with K&N filter and throttle body air foil,LTCC coil-per-cylinder kit,aluminum driveshaft with driveshaft safety loop,performance computer chip,
carl.froehlich
Mar 13, 2015 12:38 AM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
cmdeshon
Dec 27, 2014 10:06 AM
