What DOESN'T fit between V6 and V8 models camaro?
Old Feb 19, 2007 | 10:13 AM
flexus's Avatar
I have an SS v8 from '96, found a working cheap V6 for sale and i was wondering if i should buy it for parts!
What doesn't match ? except engine and trans ofc. Does the rear end have any simmilarities ? the casing? something? Interior is same color+black leather so that works... Also convertible like mine, looks like a nice part box What won't work??? anyone got a clue ?
(I have a few problems now, hit a ditch and dispaced my whole rear end, will i be able to install the arms, axle casing (if mine is bent), anything from a V6 ?)
Old Feb 19, 2007 | 10:27 AM
teke184's Avatar
rear axle is all the same...except the differential itself. it's not gonna be a posi rear. although the gears are the same.
springs and sway bars will be smaller/weaker
but for the most part they are identical cars except for engine/trans
Old Feb 19, 2007 | 11:34 AM
flexus's Avatar
Will the disc brake couplings be the same? Some V6 have drum. Also, can't i replace the differential from V6 with the one from v8? my posi?
Old Feb 19, 2007 | 12:40 PM
teke184's Avatar
not sure on the brakes...
but i think you should be able to just swap over the parts, change the proportioning valve and that's about it.
the differential will swap out fine.
Old Feb 19, 2007 | 06:39 PM
flexus's Avatar
OK any other oppinions ?
Old Feb 20, 2007 | 04:43 PM
flexus's Avatar
ttt
NewsBot
Dec 30, 2014 09:40 AM
NewsBot
Dec 21, 2014 06:55 PM
Dec 4, 2014 11:56 AM
NewsBot
Dec 3, 2014 12:30 PM
ericinsd
Jul 31, 2002 02:15 PM
