What to do with vent line to opti when switching to Vortec elbow?
Old Oct 12, 2004 | 08:44 PM
trans9_5am's Avatar
I swapped out my factory elbow for a vortech one because it had a large rip in it. The factory one had a rubber air vent tube that ran to the Opti (i believe?) and i was wondering what i should do with the line now that it is not being used with the elbow. Do i just secure it to the engine somewhere and allow air to flow through it on its own or should modify the elbow or use one of the intake lines i plugged from deleting the AIR pump? Those of you that have this intake, let me know what you did and anyone else that may have any ideas can chime in as well too.
Brandon
Old Oct 13, 2004 | 12:03 AM
Don't Look Back's Avatar
Re: What to do with vent line to opti when switching to Vortec elbow?
My Trick Flow elbow came with a rubber grommet to put in the hole you need to drill for it. Since some years didn't have the vent hose, they make the elbow without the hole. I imagine Vortech would be along the same lines.
Old Oct 13, 2004 | 12:13 AM
trans9_5am's Avatar
I think i will just try to make my own hole. Just wanted to see if it was necessary or not. Thanks
Brandon
Old Oct 13, 2004 | 06:12 AM
ChrisS95TA's Avatar
I forgot the size but I drilled my hole, tapped it using a hope depot tapping tool and it threaded in there easy. GOod luck, not too hard to do sine the aluminum is so soft.
HectorM52
Jul 30, 2017 11:46 AM
*Emilia*
May 13, 2015 09:05 AM
dfarr67
Apr 10, 2015 07:44 PM
grgguy
17
Feb 23, 2015 07:57 PM
