what CAI to get.....95 Vert with traction control
Old Sep 5, 2006 | 08:22 PM
dunkchamp55's Avatar
i see that K&N CAI wont fit with a car that has TC, so what are my options? i have seen on a few other boards that some have made their own using K&N cone filter and 20$ worth of PVC tubing.......opinions anyone
Old Sep 5, 2006 | 08:45 PM
Pandamonkey's Avatar
Re: what CAI to get.....95 Vert with traction control
Ya, you could do the homemade jobby if your wallet is light - I've never seen one that looks as good as a nice FilterPack package.
I've always liked the good ol K&N CAI made for our cars.
The other ones look odd......
Old Sep 5, 2006 | 08:47 PM
well im just concerned that having a vert if it wont fit at all? says on every site i go to that they wont work on verts, and yes my wallet is very light but im pretty handy so i think i could make the homemade jobby look pretty decent
Old Sep 5, 2006 | 10:02 PM
Give it a shot then - the worst that could happen is you're out a few buck from the hardware store.
The filter will be the largest cost, but it's not as if it can go bad......
Old Sep 7, 2006 | 08:17 PM
Dave '97 Z28 M6's Avatar
I wouldn't think that having a convertable would make any difference with the CAI fitting. The SLP CAI is a good quality piece, and works with ASR (TC). The problem with other CAI's is just a matter of interference between the brake solonoid block and CAI. I've heard of people modifying various CAIs to work in ASR cars.
Old Sep 7, 2006 | 09:30 PM
ReNxWar's Avatar
I had an SLP in my '96, it didn't have TC though. All in all I liked the SLP alot, though. Looked great.
Old Sep 8, 2006 | 04:31 AM
throb's Avatar
I have a '95 Z28 convertible with the traction control and use the K & N CAI kit. It was installed by the previous owner and where the potential trouble lies is the CAI tube will rub against the forward-most hard brake line on the proportioning valve. It's too tight of a fit between that and the left rear corner of the upper radiator support.
The previous owners answer for this was to place a piece of 1/4" thick dense foam between the CAI tube and the brake line as a buffer. There was still rubbing between the two pieces, but I guess better the brake line rubbing against that than the hard plastic of the CAI tube.
My solution was to dremel away a small portion of the plastic upper radiator support corner, providing more room. Not a lot has to be taken off and unless K & N has changed the shape of the CAI tube, I see no reason why you shouldn't be able to use one as well.
Old Sep 8, 2006 | 04:34 AM
throb's Avatar
Oh yeah, you could also dremel away a small portion of the CAI tube too, where it would contact the brake line. Getting over zealous there would net you a nice hole in the tube though, but wouldn't be that hard to patch back up.
Old Sep 8, 2006 | 08:36 AM
droptop z's Avatar
I've had my K/N CAI installed for about 5 years now, no problems. Having the 'vert doesn'nt make any difference
Old Sep 8, 2006 | 09:38 AM
kick Z tail out's Avatar
What in the hell? Who said that?
The intake comes nowhere near the traction control box and doesn't rub on the brake distribution block. I have a Moroso (very similar) and traction control on my 95.
Having had the K&N FIPK on my last Z28 (94) I must say, I think it's slightly better than the Moroso. For whatever reason... I think the inside diameter of the pipe is bigger.
Old Sep 8, 2006 | 12:43 PM
MysticTeal95Z28's Avatar
K & N says it won't fit, here is the link to it on their site:
http://www.knfilters.com/search/prod...Prod=57-3010-1
http://www.knfilters.com/search/appl...Prod=57-3010-1
Old Sep 8, 2006 | 01:51 PM
camaro81's Avatar
I'd recomend the SLP CAI too, looks and runs great.
Old Sep 8, 2006 | 02:35 PM
Originally Posted by MysticTeal95Z28
That's pretty funny. My friend has a K&N on his. The Moroso is a damn near copy of the K&N and I have no issues.
Old Sep 9, 2006 | 10:05 AM
skibbez93z's Avatar
i dont have a vert but i have a K&N on my 97 z28 with TC. i dont see how it being a vert would make a difference.
Old Sep 9, 2006 | 11:31 AM
cn97z28's Avatar
I do have TC and it still fits good,and looks even better.
