waterpump question
Old Dec 16, 2006 | 08:23 PM
95LT1conv's Avatar
waterpump question
this might sound stupid to some of you , but where is the weep hole on the waterpump in a 95z?
Old Dec 16, 2006 | 08:32 PM
It's the only hole on the bottom of the pump.
Old Dec 17, 2006 | 07:40 PM
RE AND CHERYL's Avatar
Every waterpump I've ever seen has a weep hole somewhere.
Re'
Old Dec 20, 2006 | 02:10 PM
OBE1 95Z28's Avatar
Here's a photo showing the weep hole from Shoebox's site; it right under the word "sensor" in the middle of the photo. http://shbox.com/1/temp_sensor1.jpg
Old Dec 20, 2006 | 02:28 PM
95LT1conv's Avatar
thanks
Old Dec 20, 2006 | 02:38 PM
Scotts94z28's Avatar
On a side note to the weep hole question, I have found in the past that on most of the waterpumps I have replaced for my 94 that the weep hole was around .201 in diameter, which is the tap drill size of a 1/4 20 thread. After losing my first optispark due (in part at least) to my pump leaking on my opti, I threaded the weep hole, and screwed in a hose barb into it; and thus running a small rubber hose down below the opti. After 240,000 miles, and at least 5 or 6 pumps, I have yet have one weep on my opti, like the first time.
Not sure if this is of any interest to anyone. If anyone does decide to do this just make sure to coat your tap with greese to grap hold of metal shavings.
Old Dec 21, 2006 | 03:06 PM
DJ_951's Avatar
I thought for sure you were just going to plug it. That's smart!!
Old Dec 21, 2006 | 08:56 PM
jjminch's Avatar
Thanks for the tip, I plan on doing this today.
Sergio
Jan 27, 2016 04:27 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
pologreen97z
Dec 2, 2014 10:42 AM
lbrowne
Nov 13, 2011 04:25 PM
