Water Wetter... freezes?
Old Aug 26, 2006 | 05:41 PM
bowtiepwr's Avatar
>does water wetter prevent the water from freezing also?
in other words if you added the water wetter to straight water will both freeze if the temps get low enough?
Old Aug 26, 2006 | 06:54 PM
Greed4Speed's Avatar
Re: Water Wetter... freezes?
Yes it'll still freeze.
Search engines work great to find websites and websites are full of useful info:
"FREEZING POINT DEPRESSION
Red Line Water Wetter does not significantly reduce the freezing point of water. If the vehicle will see freezing temperatures, an antifreeze must be used. Water expands approximately 9% upon freezing which can cause severe engine damage. Even in summertime, the use of air-conditioning can blow freezing air through the heater and cause freezing of the heater core unless approximately 20% antifreeze is used."
http://www.racerpartswholesale.com/redtech3.htm
Old Aug 26, 2006 | 07:13 PM
bowtiepwr's Avatar
>why use a seach engine when there are people like you to use
but thanks
Old Aug 27, 2006 | 10:21 AM
but thanks
Old Aug 27, 2006 | 10:26 AM
Gun5's Avatar
so u use this with coolant, water or just water?
Old Aug 27, 2006 | 10:55 AM
wdtiger's Avatar
all of the above.
Old Aug 27, 2006 | 07:15 PM
but thanks
I was feeling generous.
Your welcome.
Old Aug 27, 2006 | 07:55 PM
bowtiepwr's Avatar
>as posted above http://www.racerpartswholesale.com/redtech3.htm
there is an actual graph showing the difference between Glycol, 50/50, and plain water being the best heat transfer between the 3.
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
colts0455
Sep 27, 2015 01:07 PM
damnyankee36
Sep 9, 2015 07:06 PM
