washer fluid not spraying -- what to check?
Can you hear the motor activating when you try to wash? If it is working check the lines to make sure they are not clogged. If all that checks out, your washer switch could be bad.
Okay, I just popped the hood and tried it (for the first time... the post was proactive).
The motor works fine. It's pumping fluid. The problem is that it doesn't end up coming out of the spray nozzles -- it collects in the cowl somewhere and ends up dripping onto the intake manifold.
So now the question becomes: how do I go about opening up the cowl to find out what is broken?
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
