Voltage drops
Old Jul 28, 2005 | 07:43 PM
JMiller's Avatar
Voltage drops
This hasn't really been a problem yet, but I just wanted to make sure.
Anyway, I've noticed lately that my voltage gauge occasionally dips from the usual 13V to right around the red area. I can feel the AC lose some power and the lights dim (if they're on), but then it comes right back after a second or two. From what I can tell, this usually only happens when it's really hot out (middle of the afternoon, especially if the car's just been sitting in the sun for a few hours), and oddly, when I brake/turn corners.
Is this anything to worry about?
Old Jul 28, 2005 | 07:51 PM
OBE1 95Z28's Avatar
Re: Voltage drops
Your power steering pump may be failing and putting a bigger load on the system causing the RPMs to drop, thus causing your voltage and AC to drop.
Old Jul 29, 2005 | 01:12 AM
JMiller's Avatar
Re: Voltage drops
Interesting, how would I test this?
Old Jul 29, 2005 | 02:09 AM
Z28SORR's Avatar
Re: Voltage drops
When was the last time you changed your belt? Might want to check the tensioner too.
Old Jul 29, 2005 | 08:10 AM
n2ceptor's Avatar
Re: Voltage drops
Also get a load test done on the battery...
Old Jul 29, 2005 | 11:48 AM
87DJP2001's Avatar
Re: Voltage drops
Could be a sign that your alternator about to go in the dump.
Old Jul 30, 2005 | 11:47 AM
1stz28's Avatar
Re: Voltage drops
Mine will do the same thing in the hottest part of the day when I have the A/C on high max and I kick my cooling fans on high speed. The load from the A/C clutch plus the blower motor on high along with two cooling fan motors starting up on high speed really loads the charging system and it takes a second or so to catch up. At least thats my theory and I'm not going to worry about it. My battery might not be holding a load quite as good as it should and that might be playing a part in why it does it but it starts fine and charges fine so I'm not too concerned.
9t4lt4z28
Oct 2, 2015 10:28 AM
kandied91z
Sep 30, 2015 11:43 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
