Vibrating Drivers Mirror
Old Aug 17, 2008 | 06:05 PM
CamaroFan71's Avatar
As stated, the driver side mirror shakes/wobbles/vibrates when driving the car. It isnt the mirror housing itself, but appears to be the mirror itself thats a little loose. Anyway to tighten it up inside the housing??
Old Aug 17, 2008 | 10:42 PM
Granite00's Avatar
The mirror is stuck to a plastic plate that is mounted on a ball in the center. Then the two motors attatch to other points on the back of that plate. If you can tell by wiggling the mirror if the play is between the mirror and the plate, then you can fix it. If the play it the plate, then it's not really servicable and you have to replace the whole mirror assembly.
If the mirror is loose on the plate, you can pry it off, you can re-stick it to the plate with silicone or 3M mounting tape. If you crack the mirror getting it out, don't worry, the dealer sells replacment mirrors.
Old Aug 17, 2008 | 11:28 PM
Sweet. Thanks man!!
guruerror
Dec 12, 2020 06:32 PM
Apr 16, 2015 09:57 AM
karnykamaro
Feb 2, 2015 01:37 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
