Underhood Power Harness. 4th Gen
Does this harness that include's the underhood fuse block/relay center disconnect from the incar fuse block some way shape or form? such as a bulkhead connector etc..? I need to pull mine out and replace it.. if i have the ability to disconnect it and redo some of the wiring out of the car that would make things a wee bit easier..
Re: Underhood Power Harness. 4th Gen
IllusionalTA, are you referring to the one that enters on the driver's side of the firewall? I am in the same situation, while the motor is out, I'm gonna re-loom it, and grind the paint outta the engine bay, but need to know if there's an easier way to do it, since it looks like the black/gray piece is just some form of a grommet, and not a BulkHead connector right? Mine's a 93, what about you? Anyone know another route?
formula79
23
Jun 20, 2002 01:42 PM
thanks
