underdrive pulleys
Old Apr 24, 2004 | 12:38 PM
cndctrdj's Avatar
underdrive pulleys
what tpye of underdrive pulleys do you guys reccomend? i got a little bit of money and was looking at them because i need to change the belt and figured i oculd go the extra mile. i am also getting msd ignition box manual fan switch and headers just not sure wich headers yet
Old Apr 24, 2004 | 02:34 PM
95_LT1_6SPD's Avatar
Dont waste your money Use the extra money to buy more beer for installing the headers
Old Apr 24, 2004 | 03:50 PM
teke184's Avatar
i'd look into marche they are the most well known i think
although ASP makes the highest underdrive at 34% or something, i think marche is only 25%
in reality you'll probably only gain 2hp or so in peak power and maybe 10lbs of torque, but here is a gain over the entire rpm band as well....
Old Apr 24, 2004 | 05:34 PM
cndctrdj's Avatar
im just looking at the little bolt ons right now once i get all of those then i will look into a cam and heads so again every bit helps
Old Apr 24, 2004 | 05:58 PM
Zerocool's Avatar
i had march on old LT1, they worked fine, no charging problems
Old Apr 24, 2004 | 09:48 PM
ABA383's Avatar
I have the ASP crank pulley balancer combo....been on the car for 10 years with no complaints...5-9 rwhp...a little hp here...a little there...every little bit helps...that car length may be the difference when you're racing that Cobra....
--Alan
Old Apr 24, 2004 | 10:59 PM
Rashiki's Avatar
WS6.com comparison
AviatorDave
Dec 19, 2016 06:35 PM
RUENUF
Mar 13, 2016 03:37 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Slayer
Aug 17, 2015 03:55 PM
Rde Bandit
Mar 21, 2015 10:17 PM
