Turn signal stops clicking fast flash
97 Z28 - When turning left or right blinkers on, the turn signal will click for several seconds then stop and the light will fast flash (both inside and outside) sometimes the clicking kicks back in and the signal behaves normally.
All the lights are fine.
Bad blinker socket? (I'm puzzled by the fast flash... usually a bad blinker just causes the light to either stick on or off...)
Fast flash is usually caused by high amps. This sometimes happens when one of the lights burns out, the other will flash faster. I would check the sockets, wires and ground for corrosion. Also it might be something in the steering column, turn signal mechanism. The flasher itself might be getting "tired". Check the easy stuff first.
stangspank
Nov 13, 2015 01:02 PM
HuJass
Aug 29, 2002 02:30 AM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
