turn signal + low fluid level
I have to replace a turn signal in the front left of my car, does anybody know how to get to the lightbulb? also there is a gauge right next to the tach it' s like a box with very little fluid with an arrow going down. If i let my car sit for a while it goes on but if i shut the car off and start it again it goes off. is that trans fluid low or coolant, thanks for replying.
Re: turn signal + low fluid level
What car/year? The light sounds like it's for low coolant.
You change the bulb from underneath the car. You just take out a few bolts to drop down the cover for the bottom side and you are good to go.
If you are low on fluid, the cheapest I found is here: http://kalecoauto.com/index.php?main...&products_id=6 |
'93 Camaro? Make a sig for your profile, so people can respond faster w/o searching. Not being a wise guy, everyone's helpful here, just trying to get you faster answers. :)
thanks for the quick replys, and sry about the not knowing what mycar is, i will definetly make a profile.
alright i made my signature
