Turn Signal Lever
Old Oct 20, 2004 | 02:29 AM
93Z28rare's Avatar
Turn Signal Lever
Today i was driving, and as i made a left hand turn into a driveway, my turn signal lever just got loose. now i can't make a right or left turn signal. The lever is completely loose in the column although the wipers and high beams still work. How do i fix this?
Old Oct 20, 2004 | 10:56 AM
NEWBIE T/A's Avatar
Exclamation Fairly easy, although it does take some special tools.
Thanks to Shoebox , though, you have an illustrated guide !
See : http://shbox.com/ignsw/ign_switch_repl.html
*EDIT* Good stuff, to be sure - I meant to link you to this, though.
http://shbox.com/1/steering_column_exploded.jpg
His excellent site (home) is :
http://shbox.com/1/4th_gen_tech1.html
Good Luck !
Britt
Old Oct 21, 2004 | 01:51 AM
93Z28rare's Avatar
Re: Turn Signal Lever
I'll take a look at the info given and work from there. thank you newbie and shoebox for the help.
Old Oct 26, 2004 | 03:45 PM
93Z28rare's Avatar
Talking Re: Turn Signal Lever
thank you for the help Newbie. you were right the job was fairly easy with the correct tools. I found the problem to be a broken signal switch arm. how that broke is still a mystery to me. instead of replacing it, i went ahead and had the piece welded back together. i smoothed out the part of the weld that was in the way, and i put everything back together. everything works smoothly and i have my signals back again.
thank you again Newbie. and thank you shoebox for the wonderful diagram
Old Oct 26, 2004 | 04:09 PM
NEWBIE T/A's Avatar
Talking I always like a happy ending !
Glad to hear it worked out.
Britt
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
