turn signal issue. HELPPPPPP
Old Feb 25, 2010 | 09:41 AM
z28camaro1090's Avatar
where is the turn signal control switch and how do i go about replacing it? I have been told it is bad since my 2 front turn signals will not light at all. and the rears are just constant when the turn signal is engaged does this sound like the issue? I need some help my inspection is up and i need to get it inspected
Old Feb 25, 2010 | 10:16 AM
Marc 85Z28's Avatar
Turn signal switch, or the turn signal flasher?
If you cannot locate the turn signal switch on your own, well, I don't know what to tell you
The flasher is located behind the dash, just to the right of the steering column.
Old Feb 25, 2010 | 10:27 AM
I know where the switch and flasher are located. I was more asking how to go about changing the control because someone told me the steering column has to be compressed to do it? also does this sound like what the issue is or no?
Old Feb 25, 2010 | 12:14 PM
rod442's Avatar
Im pretty sure that when I switch mine on and a front bulb is burned out, the rears light up solid. No quick flash like most new cars.
So, this might sound silly, but did you replace the bulbs?
Old Feb 25, 2010 | 01:04 PM
NEWBIE T/A's Avatar
Exclamation Read/view from the bottom up.
This is a great write up on how to tear the whole column down off Fiero Forum.
What has to be compressed is the lockplate spring, which will allow you to remove the snap ring that holds on the lock plate, and go from there.
I agree that bulbs, or bad contacts in the bulb holders, would be the more likely cause.
However, you can unplug your turn signal switch at the bottom of the column & plug in a new one w/o doing any damage and trouble shoot that way.
Of course, that assumes that you have access to a working switch ...
Good Luck !
Britt
Old Feb 25, 2010 | 01:18 PM
no i did not replace the bulbs the front . both front bulbs arent lighting. the rear ones are solid.. do you think both bulbs are bad?
Old Feb 25, 2010 | 02:00 PM
rod442's Avatar
it would be the easiest thing to check. and Im almost positive thats how mine act (on a firebird, but should be the same). I have no housings for my bulbs, so the air can get to the innercoolers better.
so the wiring and the bulbs are just tucked up in with the airdam, bumper and stuff. and I know when a frt bulb is out, to let people behind me know that I am turning; I have to manually click the stalk on and off to make it cycle. and the bulbs go bad a lot due to vibration, and water. lol.
Old Feb 25, 2010 | 02:52 PM
Marc 85Z28's Avatar
Possibly. Or... The front turn signal sockets have a nasty habit of picking up moisture. They contacts in the sockets corrode, usually on the ground side, and cause all sorts of weird problems. It may not be your problem, but checking that first is easier than pulling the column apart.
Old Feb 25, 2010 | 04:56 PM
coco95z28's Avatar
when one of my front bulbs went out, they were both on, but when i hit the left it would just turn off, also it made the rears stick on... i replaced the bulb and that fixed it.......(it was still lit, just didnt blink...)
Old Feb 27, 2010 | 09:21 PM
Fixed the flasher.. now back lights are blinking still othing from the front 2 didnt get a chance to change the bulbs do you guys think its the bulbs. i see moisture in the lens
Old Feb 28, 2010 | 07:20 AM
AL SS590 M6's Avatar
Moderator
I think that it's time to move this from engine tech to general tech so that you can ignore the advice of those folks too.
Old Feb 28, 2010 | 07:56 AM
edz97's Avatar
I went through this on my 97 Z28 with the front turn signals. I spliced in new front TS bulb sockets (they were badly corroded), you can get them at AutoZone for about 8.00 each. I also went ahead and replaced the bulbs also.
Is the problem with the 93 or 98? I ask because the later model cars have daytime running lights and there is a DRL module behind the radio. I still had problems with the signals and had the option of replacing the module or just unplugging the blue connector from the module and let it hang. I priced the module (250.00) so my plug is hanging.
The drl's wont work but no more signal problems.
Old Feb 28, 2010 | 09:34 AM
CharlzO's Avatar
Especially with the cost of bulbs, it'd be foolish to start tearing into anything else without at least checking them first. Most cars, as stated, the rest of the blubs won't act properly if another is blown.
Old Feb 28, 2010 | 10:15 PM
AFK9's Avatar
Had this exact same problem on mine. Replaced the front bulbs and was good to go. Does the arrow on your dash just stay on without flashing when you turn the signal on. Sounds like your bulbs are bad. Replace them first. Its cheap!!!!!
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
