turn signal doesnt work....
Old May 4, 2004 | 01:26 AM
QCKZ28's Avatar
my left turn signal works perfect.
when i turn the right side on the green arrow light in the dash stays on, but doesnt blink like the left side does. and the turn signal doesnt blink at all on the right side.
i replaced the right rear turn signal bulb a few days ago (it was not working) i think the guy at advance auto gave me the wrong bulb.....
could it be anything else?
i just removed my HVAC system also, this is the first time driving the car since changing the buld and removing the hvac....
everything else electrical works as supposed to....
jesse
Old May 4, 2004 | 01:48 AM
ucnu112's Avatar
You need to check the 'blinker' itself. It's a little $5 part, behind/below your steering wheel... around your knees. That's what regulates how fast/how often your turn signals blink. There was a thread about it not too long ago, and there was a picture posted in it.
Fred
Old May 4, 2004 | 01:53 AM
QCKZ28's Avatar
if the blinker was bad, it wouldnt work at all right?
the left side works just fine.
i was worried that broke i something when i pulled the hvac.
if i had the wrong bulb that would be the problem right?
Old May 4, 2004 | 01:56 AM
ucnu112's Avatar
when my blinker was going out, it would work sometime, or blink fast or just go on steady.... no consistency until it stopped working completely. I'm no help on the bulb issue, though.
Fred
Old May 4, 2004 | 01:59 AM
QCKZ28's Avatar
thanks for the help anyway. my blinker is always steady and consistany (on the left)
i will figure it out tommorow, and post the results
jesse
Old May 4, 2004 | 06:55 AM
RENE95Z's Avatar
Staying on steady can be a sign that it is going bad. Blinking more rapidly can be a sign that it is going bad. Not blinking at all is a definite sign it is bad. Personally, I would change the blinker before driving myself crazy trying to figure out why this bulb works in this socket and not in that socket.
http://shbox.com/1/flashers.jpg
Old May 4, 2004 | 09:13 AM
96Jimula's Avatar
I had the same problem and it turned out to be the bulb. I tested this by using the emergency flashers. The left side was fine, but the right side bulb was not flashing. The first bulb I put in turned out to be bad, so maybe that's your problem too. Second replacement bulb has been working great.
Old May 8, 2004 | 07:49 PM
CCRJon's Avatar
It's either turn signal bulb (front or rear) on the side that doesn't work. Put on your flashers, get out and check all the bulbs. Replace the one that does not work.
Old May 12, 2004 | 09:19 PM
QCKZ28's Avatar
the bulb i replaced was in the wrong way....now it works perfect
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
