Traction Control switch
Tried doing a burnout today. Wheels spun as long as I kept my foot on the gas but no smoke what so ever. My buyer's guide says there is a traction control switch on my car but I can't locate it. I was thinking this might be the problem. I own a 95', thanks. Help
Re: Traction Control switch
If you do have traction control, it will be located above your radio - the button is a left to right toggle and it says "ASR" - stands for Automatic Slip Regulation. IE - Traction control.
When you start the car, it will be on automatically - just flip the switch and a light will come on the button and the dash near the speedo indicating it is off.
pretty sure it's right by the fog light switch actually
he has the 93-96 style interior (my fav
) while you have the 97+ interior
my 95 doesn't have it and iirc, not many 95s did
if there isn't a switch next to your fog lights, then you dont have it
) while you have the 97+ interiormy 95 doesn't have it and iirc, not many 95s did
the switch is located below the radio in front of the center console to the left of the cd holder spot. I believe next to the cig lighter. If you were to have it and it was on, the gas pedal would literaly push your foot right off of it and you would lose all fuel and power to the wheels.
Originally Posted by orbitalshock2k
Nope I don't have it. Only option the car didn't come with. Thanks
You say you tried to do a burnout but there was no smoke........did you get the rear wheels to break loose at all?
The traction control does two things.
1. Throws the gas pedal back up at your foot when you floor it.
2. Engages the rear brakes to stop the spinning.
Is that what happened to you?
Originally Posted by BigEvil
Not on a Camaro, you're thinking of a Firebird. The other guys were dead on.
no your wrong. I'm looking inside my 96 Z28 right now and it's just how I mentioned it.
Javi Fierros
Jun 10, 2015 03:35 PM
squarehead
Jan 15, 2015 07:02 PM
Jul 4, 2005 05:00 PM
