torque arm bushing bolt
Old Aug 13, 2004 | 11:03 PM
SHIZNIT's Avatar
Tonite while driving, my torque arm came loose. The bolt on top of the bushing that clamps it together worked itself out. What size bolt is that? Thanks for any info.
Old Aug 14, 2004 | 07:24 AM
Cman's Avatar
Re: torque arm bushing bolt
I'm not 100% certain but I believe it's a M10 or 12 by 1.25 thread pitch about 1.5" long.
I have the bolt at home in the garage, don't use it now since I needed a shorter bolt to keep the other bracket bolted onto the tranny when I did my Spohn TA. I could measure it and get back to you but it won't be till after the weekend.
Tony
Old Aug 14, 2004 | 07:38 AM
SHIZNIT's Avatar
Thanks for the info, I still cant figure out how the hell it worked itself out
Old Aug 14, 2004 | 08:25 AM
Cman's Avatar
Bolts do work themselves loose sometimes especially if you've removed the bolt before to add an ES Ta bushing or something. When you get the correct bolt add a bit of blue locktite to the threads before you install it should stay put after that.
Tony
Old Aug 16, 2004 | 04:08 PM
Cman's Avatar
Not sure if you figured out the bolt size yet but I'm back from my weekend trip and did some measuring. The bolt you need is a M10x1.5mm thread pitch, 15mm hex head with a lock washer and the UHL is 1 1/8" long. If you get a bolt like that it'll work for ya. Hope this helps you.
Tony
Old Aug 16, 2004 | 04:27 PM
SHIZNIT's Avatar
Tony
I bought those 2 bolts and they won't fit properly so I called the service dept and they told me 1.5 thread. I worked out great. Got it done just in time to install my jet hots. Thanks for the quick replies
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
