throttle linkage cover
Old Mar 23, 2007 | 03:08 PM
canuck94z28's Avatar
I am reinstalling the 48mm t.b on my 94 and need pics/diagrams on how to install the plastic cover that goes over the linkage and how to hook up the cruise/throttle cables.Any reply,s appreciated.
Old Mar 23, 2007 | 05:14 PM
94_PatriotRed_Z's Avatar
leave the plastic guard off, mine has been off for over a year. it helps clean up the engine bay
Old Mar 23, 2007 | 11:15 PM
The 52tb was not compatible w/the cover and in the year it was off ,the cover kept the throttle spring cleaner ,but i want to reinstall it, so thanks for the reply.
Old Mar 24, 2007 | 03:58 PM
OBE1 95Z28's Avatar
Pretty straight forward, the cover has 2 posts on the bottom that fit into 2 holes in the intake manifold. On the top there's a small bracket that mounts to the TB top driver's side bolt that clips onto the cover and finally there's a small screw that that holds the top of the cover.
Old Mar 25, 2007 | 02:55 PM
Thanks for the reply.It looks like you hook linkage up first and then the cover.
Old Mar 25, 2007 | 04:26 PM
OBE1 95Z28's Avatar
True, link first, then cover. The link should be the same hook-up as your current larger TB.
Old Mar 28, 2007 | 02:09 AM
Again thanks for the reply and the install went smoothly and i opened the throttle manually and pushed the gas pedal down and every thing seems to be working properly.BTW the spring of the factory tb is much lighter than the stupid tighter feel of the BBK 52TB which has caused me all kinds of grief,drivability issues,etc! IT,s going to feel good to be able to enjoy driving again lol
Old Mar 28, 2007 | 09:39 AM
OBE1 95Z28's Avatar
I've had a BBK 52mm TB on my car for 100,000 miles and can't complain. I got one of the very first units so I don't know if quality went downhill later. The only issue I ever had was the rpms hanging after I cleaned the TB with 20K miles of use. I dabbed a little oil on the butterfly rod where it enters the TB housing and the rpm hang went away.
HectorM52
Jul 30, 2017 11:46 AM
edman
Jan 25, 2015 02:41 PM
David Dorris
Jan 17, 2015 08:10 PM
Queens94z28
Dec 20, 2014 09:11 PM
