Theft is [upsetting]
Well, Im lucky to still have a car as I had been having an electrical issue with the car that was causing issues.
Anyhow, went out to the car to grab a tool I had left in it to find my doors open, hood popped, amps gone, stereo gone, valentine 1 gone, and steering column F@#$ED.
What I would like to know is how hard is it to replace a steering column?
Here are pics of the damage: http://community.webshots.com/album/291082066iaqRWG
Thank god the car didn't run
Re: Theft is B*t*h
That looks like they knew what they were doing. The column got jacked pretty good. Now you know to either not put a stereo in or to cover the amp rack...Or get the custom one that mounts onto the back under the hatch so you can't see it.
Re: Theft is B*t*h
Replacing the column is easy. Just get a new one and go from there. I've had mine out to fix the dreaded "tilt column play" problem. Tearing it all apart to fix it was not a picnic. Getting it out and in was no problem, though.
Re: Theft is B*t*h
Originally Posted by anasazi
impossible to steal a 4th gen by "hot wiring" it like they tried to do
prolly some punk kids
Re: Theft is B*t*h
Originally Posted by DrewHMS97SS
So how are these cars stolen without the keys? From what I see here it looks like they were trying like a ****. I though if you cut the VATS wire, and connected it to a battery it bypassed.
Typically a tow truck is used to steal our cars. If you are not in a hurry, you can try all the different resistances until you eventually find the correct one. I've heard of a tool that plugs into the vats harness and allows the user to select different values with a ****. This method could be time consuming.
Re: Theft is B*t*h
if i recall correctly, there are 26 different resister combo's
times this by the timeout period, which is something like 3 - 5 minuites per bad resister, and you've got a long long long wait.
only way your getting an f-body is via flatbed or by having the key.
Re: Theft is B*t*h
Not that I have ever to steal a car but I am sure if the guy wants your car bad enough he will find a way to steal it.
Re: Theft is B*t*h
Originally Posted by Pandamonkey
Jeez.......what happened to the steering wheel?
Is that fire damage?
Re: Theft is B*t*h
Originally Posted by 1KillerV6
No, I think thats the powder for the finger prints. Although I thought it was white?
Re: Theft is B*t*h
Originally Posted by Getsome17
I dont think it is that hard at all. Instead of trying to find the right resistance to get the car to start you could just bypass the whole vats system by grounding out the vats wire on the relay in the glovebox.
