t-tops keep leaking and i cant take it anymore
Old 01-22-2007, 08:37 PM
  #16
Oddball's Avatar
My third gen has a small adjustment to the latch kind of like a small can. Adjusting this fixed my leak instantly after everything else failed. I had to take off the trim on the car but it was easy once i removed the trim piece.
Oddball is offline
Old 03-23-2008, 07:22 PM
  #17
Oxygen454's Avatar
I have the same problem coming from the actual t-top. Im going to figure this out and try and post vids on it. Its a major PITA!
Oxygen454 is offline
Old 04-19-2008, 01:56 PM
  #18
Oxygen454's Avatar
Good News!!!
Im in luck! I finally found where the leak is coming from!!!!! Some how water is getting under the t-top and leaking into the internal plastic covered area where the lock handel sits inside. I opened the ttop and turned it to the side and a whole bunch of water poured out! The seals all around the t-top on the car frame where dry so its filling up inside the t-top and running out along the plastic that meets the inside of the car.
Now I just have to find out where the its coming from. Maybe the seal is broken from the window to the t-top frame? Sounds like a silicone job for me...
Oxy.
Old 04-19-2008, 01:59 PM
  #19
Oxygen454's Avatar
(Water filling inside t-top)
Old 04-21-2008, 12:04 PM
  #20
slomarao's Avatar
i use mothers interior spray for rubber and the dash. Its good, you can tell the rubber looks much better after using it. Its expensive though, 12 bucks a bottle.
slomarao is offline
Old 10-28-2008, 02:16 PM
  #21
spydercam's Avatar
Oxygen454 did you ever fix that leak right there?
spydercam is offline
Old 10-30-2008, 11:15 PM
  #22
Oxygen454's Avatar
Hey spydercam
Ya I had to remove the cover off of the t-top to expose the latching mechanism. Then I used silicone on a screw that holds the weather stripping in ... and also at both ends where the weather stripping meets the car. Was leaking in 3 or 4 points. I had been driving around for 3 months with the cover off my t-top lock mechanism haha
Also I used a silicone spray lube on the locking mechanisms and now they are really easy to lock and unlock. Almost too easy. Before you would have to give them a good little shove to close but now they just slide shut.
Old 11-05-2008, 01:37 PM
  #23
Sick97SS's Avatar
oxygen454's leak is exactly where mine was dripping in from, I used clear silicone and globbed it everwhere i could possibly see in that area. no more leaks here!
this was drivers side only, passenger side has never leaked a drop.
Sick97SS is offline
Old 11-05-2008, 01:59 PM
  #24
whyrun's Avatar
smear a coat of vasoline on it will make a great seal it works well and its petrolum based so it will hang around awhile KY is waterbased wouldnt think it would work to well
whyrun is offline
Old 11-07-2008, 01:56 PM
  #25
nickylip's Avatar
Had that problem a while ago
nickylip is offline
Old 11-08-2008, 12:33 PM
  #26
Oxygen454's Avatar
wow finnally a thread on successful t-top leak fixing, never thought I would see the day By the way, Vaseline works only for a short while and for the drivers side, if you use the window a lot if gets all over the window and doesn't work more than a day or two.
I think the screw that holds the weather stripping on is the biggest culprit for leaks.
Old 11-14-2008, 03:55 PM
  #27
spydercam's Avatar
+1 on that Oxygen.
Thanks alot for answering that question I am gonna give it a shot! I'll let you guys know how it goes.
Old 11-21-2008, 08:52 PM
  #28
Oxygen454's Avatar
We are having down pours and 100 plus km/h winds right now and so far not a drop of water inside!
Old 11-21-2008, 08:55 PM
  #29
seawolf06's Avatar
Did you just use black silicone or what?
seawolf06 is offline
Old 11-21-2008, 08:59 PM
  #30
Oxygen454's Avatar
I had some clear RV silicone laying around.
Quick Reply: t-tops keep leaking and i cant take it anymore
