sub frame connectors
Old Dec 4, 2004 | 01:12 AM
Black02Z's Avatar
now i know what they do but where exactly are they installed pics would be helpfull
Old Dec 4, 2004 | 10:06 AM
lbrowne's Avatar
Re: sub frame connectors
Just for info, your car will tighten up alot after these..... (SFCs in general)
Old Dec 4, 2004 | 09:42 PM
1stls1's Avatar
Can you install these on the ground, or does the car need to be in the air? Is it poss to install wrong, meaning, the car on being straight?
Old Dec 4, 2004 | 10:27 PM
Frank89IROC's Avatar
Installing sub frame connectors in driveway
I installed Jegsters bolt on(from JEGS), in my driveway. I did jack up one side of the car that I was working on with jack stands. They can only go on correctly. If you try to place them wrong, it just won't line up. (On my 94TA).
Old Dec 4, 2004 | 10:55 PM
lbrowne's Avatar
For SFCs to be installed correctly, the car neesd to be under load. Meaning under its own weight on a level surface. A lift in a shop is perfect
Old Dec 5, 2004 | 07:35 AM
1stls1's Avatar
By a lift, you are talking about a drive-on lift. With the bolt on, are they just bolt on like it says, or do you have to remove something and "share" the hole?
Old Dec 5, 2004 | 08:03 AM
87DJP2001's Avatar
If you are going to get SFC's have them welded on. Bolt on ones are a waste of money in my opinion.
Old Dec 5, 2004 | 11:14 AM
lbrowne's Avatar
I have bolt ons and I love them. The difference in the car is night and day.
Also by lift yet thats hwat I mean, a drive on one.
Old Dec 5, 2004 | 11:41 AM
KPZ-28's Avatar
Sorry about the hijack, but did your bolt on connectors eliminate any dash squeaking or is it better to weld them on?
Old Dec 5, 2004 | 11:56 AM
87DJP2001's Avatar
You may love those bolt on SFC's now, but given time they will start getting loose. And then you will have the same flex as before.
Old Dec 5, 2004 | 01:31 PM
JoeliusZ28's Avatar
ive got pics in my cardomain if you want em (page two of sig) - kenny brown double diamond weld ins
Old Dec 5, 2004 | 04:52 PM
Super Slow '97's Avatar
Can't you buy some bolt on sfc's and then just have them welded or are they different?
Old Dec 5, 2004 | 04:58 PM
lbrowne's Avatar
You can weld your bolt ons on , many have done it.
Old Dec 5, 2004 | 05:39 PM
Bolt on sub frame connectors
I have the Jegster bolt on sub frame connectors, After installing them myself, I went to a muffler shop, had them welded for $20.00. You'll notice the car will be much stiffer on bumps.
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Double aught
Oct 2, 2015 11:29 PM
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
