Stripped Torx bolt!
Well I'm back to working on my suspension again today. I started to work on the front drivers side and I cant get those damn torx bolts out near the master cylinder. I stripped the sheisse out of the bit and the the recess in the bolt head where you stick the bit is almost completly stripped too. Any ideas on how to get these bolts out? Is there an "indestructible" torx driver bit I can buy cuz my crappy one stripped without me even trying?
Re: Stripped Torx bolt!
are you talking about the shock tower bolts? first make sure that you have teh correct size. Torxs sizes can be confusing, some seem to fit but of you go the next one higher it fits better. a good example is the screws on an IAC motor. they are T20, but a T15 looks like it will work, but will usualy strip. Get teh right size and order a snap on bit. They have the srongest. I have never broken one.
T50 is pretty large. I was guessing maybe a T30 or 35.. I would have to grab my torxs set at work to find out
They make a new style of Torx bits called Torx +. They are so much better because they had thicker points to help prevent the stripping out. Worst comes to worst you might have to drill it out. Or try to hammer a bigger bit in there and turn it out.
I couldnt find a T52 so I got another T50. I could have sworn I saw a T52 there just yesterday. Anyways I managed to get one of the bolts out. I hammered bit in so it fit snugly then pulled like hell. Ill try getting the other one out tomorrow. Thanks.
Originally Posted by 97WS6SCharged
If you've stripped the torx, you may try using an allen wrench.
a lot of times an allen will strip the bolt. It works sometimes but not all. Just always be carefull.
yeah, the snap on design has been improved further. I do not preach to only buy snap on tools even tho I am a mechanic but for some things there are just no better tool out there. I sware by there Torx socktes, allens, and comfort grip screw drivers. that and there impact swivel sockets. they rest a slightly cheeper high end tool works great.
the best advice that I can give anyone with torx. Have a good snap on set. even when you find the one that fits try the next size up. always aply pressure down on the bit while you turn.
another thing is that a lot of cheeper sets do not come with a T27 bit. Thats a special bit that a T20 and T30 will not work on. Snap on has them. someone lost mine
Originally Posted by Chuck!
The man who created Torx bits has a special place in hell between Hitler and Stalin.
Got it replaced the next day since the Snap on guy came in.
