Strange Humming Noise?
Old Aug 9, 2010 | 10:34 PM
lantern's97Z's Avatar
I noticed last week that when the car is at idle,i get a strange humming noise from underneath or the engine bay. also noticed if i accelerate it stops. Another thing is my ac has to be charged but if I turn it on it goes away sometimes? Can the switch be bad? Anyone come across the same issue?
Old Aug 10, 2010 | 06:37 AM
frankzlt1's Avatar
Sounds like you may just have something loose with the exhaust , a heat shield or just exhaust pipe hitting under the car making it sound like it was coming from the engine compartment. Especially if you changed the exhaust you have a bigger chance of noise. Best thing to do is get a buddy and have him/her either sit the car with it in gear or running and you look around the car and pinpoint were the noise is coming from.
Old Aug 10, 2010 | 07:01 AM
brian12's Avatar
Are you sure its not coming from the back of the car? My fuel pump makes a humming noise when I get low on fuel.
Old Aug 11, 2010 | 01:46 AM
I figured it out, it was a vacuum leak. The rubber T fitting coming off the PCV valve split in half..
Nayr
Mar 3, 2023 08:34 PM
RUENUF
Mar 13, 2016 03:37 PM
autoxr166
Sep 25, 2015 04:21 PM
tdigger9899
Sep 7, 2015 10:56 AM
rideordie
Sep 7, 2015 08:22 AM
