Starting car for first time in 6 months
Old Jan 8, 2008 | 11:32 AM
SpeedDemon02SS's Avatar
As the title says, im starting my car for the first time in 6 months. When i put it away it had all new fluids (mobil 1: oil, tranny fluid, rear diff oil, fresh 93 octane gas). Is there any precautions before i start her up? How can I prime the engine with oil without stating? Can i pull the fuse for the ignition and crank it over for a bit? I just dont want to cause any undo wear on the motor.
Old Jan 8, 2008 | 01:52 PM
n2ceptor's Avatar
I just started mine up without reving and let it sit for a couple of minutes idling before going into the throttle....
My 93Z sat for 7 1/2 months and no problems..... Got to love deployments...
Old Jan 8, 2008 | 03:22 PM
reamo04's Avatar
mine sat for about 3 months...it smoked a little bit for about 10 minutes when i first started it, took it for a drive, got it back, and, no more smoke. Think it mighta just been burning off some old gas on the plugs or something, idk?
Old Jan 9, 2008 | 01:59 AM
wdtiger's Avatar
6 months is nothing. Just fire it up and let it warm up to temp just to make sure everything is ok with it (no leaks, overheating, etc).
Old Mar 4, 2008 | 12:45 PM
should I change my oil? I just changed it (with mobile 1) before I put it away. Maybe drove 100 miles on it.
Old Mar 4, 2008 | 09:13 PM
2000GTP's Avatar
I would just start it up and let it warm up. As for the oil, personally, I would change it. With the car being idle for six months, there is the possibility for moisture getting into the oil.
Old Mar 5, 2008 | 07:09 AM
teke184's Avatar
just start it as usual. the oil should be alright, definatly let it get up to temp and keep it there for a while.
Noenav
Mar 1, 2019 07:38 AM
Britbilly
Jan 7, 2015 08:49 PM
NewsBot
Dec 3, 2014 12:30 PM
USAirman93
Nov 24, 2014 03:37 PM
