Something is leaking
Old May 5, 2006 | 11:07 AM
YARDofSTUF's Avatar
Have a leak under my car, looks to be pretty small, sat for 6 months and there isnt a lot of liquid. Try for a pic later.
Its on teh right side, just behind the tire and in a bit, almost lines up to where the dash meets the windshield.
Its been on jack stands in the back so its got a different angle from that, dunno if that could be a factor. Car has pretty much always leaked coolant but usually on teh top of the engine.
I have no AC stuff so I know it wasnt from that. Need to find my camera.
Old May 5, 2006 | 01:01 PM
Z28SORR's Avatar
Re: Something is leaking
Well NOTHING should be leaking, so if SOMETHING is leaking, I would definitely fix SOMETHING!!!!
Do you still have a heater core and heater hoses?? Could also be that the drain for the air vent intake on that side is partially blocked.
Old May 5, 2006 | 01:11 PM
YARDofSTUF's Avatar
no heater core, dont know about hoses, without the core I would think I dont, removed the fan that blows air through the vents and removed the HVAC ducts on the right side.
I like the Fix something idea, I'll fix the loose stereo and hope the leak stops
Old May 8, 2006 | 02:30 PM
Z28SORR's Avatar
Sorry, can't think of anything else that would have water in that area.
Old May 8, 2006 | 02:42 PM
FNDRB58's Avatar
Confirm, is it leaking inside the car or underneath the car?
Old May 8, 2006 | 02:53 PM
YARDofSTUF's Avatar
Underneath, camera is charging.
Old May 8, 2006 | 02:55 PM
YARDofSTUF's Avatar
Its cool. I was more worried someone would be like, Its leaking there? Oh man you are so ****ed! lol
Old May 10, 2006 | 11:34 AM
YARDofSTUF's Avatar
http://i34.photobucket.com/albums/d1...STUF/leaky.jpg
Theres the pic, its maybe a bit more than just in from the tire, but not alot.
Old May 11, 2006 | 09:50 AM
Z28SORR's Avatar
Any water that gets into the HVAC system air intake in front of the windshield runs to either side and down the gap between the fender and body. The drains are just a couple of gaps between the panels in the area your showing in the picture. If these get glogged water can collect in this area. Also sometimes water can get into the area behind the inner fender well. Doesn't sound like anything to worry about!
Old May 11, 2006 | 09:56 AM
Stoopalini's Avatar
There is a metal coolant steam pipe which runs across the back of the motor, from one side to the other. It is above the bellhousing, under the intake.
This could the cause of your leak?
Thomas.
Jeff1904
Jun 5, 2016 05:00 PM
magman
Apr 15, 2016 03:08 AM
blac94Z
Nov 4, 2015 01:59 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
